Hello everybody, a bit of time since I wrote last time.
So, recently I got into those DIY kits from China (always the same: function generator, mini scope, frequency counter, component testers...). Very fun to build and they also works quite decent, at least for an amateur.
I've always powered them using standard 9 volts batteries; now I would like to power them more permanently, so using a power supply. My first though was to use a small wall wart switching power supply, cheap ones from Amazon.
Here's my question: we all know that switching power supplies have floating voltages. In many dc power supplies I've measured 80-90V AC between ground and DC positive lead. Ok, it's a very small current, but I would like to use those kits with my lab equipment, especially my analog scope. And, from what I know, there's always a problem when an oscilloscope referenced to ground probes something that isn't, with several tens of volts AC floating. How can I solve this problem?
I know that using a linear wall wart power supply would solve the problem, but now they seems to be impossible to find!
Thanks for the future answers!
