Hi guys!
I have a chinese DVR that just stopped functioning. It turns out that it was its external power supply.
Its a 19V, 3A switching power supply. One of the capacitors leaked. I measured its ESR and its way
too high. All other capacitors are fine.
Faulty CapacitorBelow are some photos of the PCB:
PCB Top
PCB UndersideThe faulty capacitor has a value of 470?F @ 35V but I only have a 680?F @ 35V one.
My question is, do you think that its ok to replace the faulty one with a larger capacity value?
I've read that in some situations that this might not be a good idea, such as:
-- 1) If total capacitance is too high, the turn-on surge current could be high
enough to trigger the OCP (over-current protection) in the ATX supply and
on the on-board regulators themselves.
-- 2) In this type of circuit, incorrect values can cause parasitic oscillation, which
will cause over-current, overheating and premature cap failure.
If this capacitor is a filtering one maybe it might be ok to replace it with a larger one.
Its near the output stage of the power supply.
What do you think?
Thank you!
George.
