If power supply will be 15 feet away, you will have 30 feet total, so your led strip voltage will be lower, voltage dropped will be around 0.7V. Thicker wires will result in lower drop. You could also try to get a power supply with some output regulation, I don't know if branded ones have something like that, but most of the chinese power supplies have a small pot near output terminals.
