Thanks for all the replies!
I don't have a HAM licence so I'm only allowed to make recievers.
I have been wanting to try and make a
AIS receiver for my family's boat. AIS is transmitted with GMSK-modulation at 161.975 MHz and 162.025 MHz. I'm guessing I would need a low noise pre-amplifier and then some buffer before mixing the signal down? I was planing on building an ordinary FM radio receiver first though since the demodulation is more straight forward (or maybe it isn't, but FM is more familiar to me) and it uses similar frequencies.
You can supposedly receive weather image data from both satellites and radio stations which could be fun as well. Not sure at what frequencies.
Then there is the 433 MHz ism band that all kind of cheap sensors use, would be nice to be able to log some of that data to a micro controller. I know there are cheap 433 MHz modules, but that would be cheating.
It would also be cool to calibrate my OCXO with the DCF77 signal from Braunschweig, but that is broadcast on 77.5 khz so in that case it's more about the antenna I suspect.
I have also been planning on building this counter:
http://lea.hamradio.si/~s53mv/counter/history.htmlmore details:
http://www.vhfcomm.co.uk/Counter.pdfBut I haven't been able to find all the parts for the amplifier stages so I need to figure out what replacement parts to use, especially for the "ERA-2 MMIC"
That part is way over my head unfortunately. The digital and the low frequency stuff I am familiar with though. The design is from 1998 so maybe there are better chips to choose from now?
A few common ones to get you started (some are quite old but you'll come across them in old circuits).
These walkthroughs of simple transceiver circuits show where some of the above devices are used.
Thanks for the list. The "Beach 40" radio looks very nice!
I might try and build the receiver part. I'm not entirely sure about the function of the bifilar toroid after the 2n2222 stage though, the other parts I think I understand.
For output power under about a watt, you can get an actual, modern RF transistor for a buck or two.
There are also nowadays plenty of inexpensive RFICs and MMICs, even high speed differential amps and op-amps. Discrete transistors are used less and less as time goes on.
They were actually cheaper than I remembered, but the problem is there are thousands to choose from and if you don't know which parameters to look for it's difficult (and eventually gets expensive to buy new ones). RFICs are nice if you wan't to get something done quickly, but not as much fun, it's like buying a complete radio.
