Decades ago we had the ARRL handbook which walked you through all this.
----- basically its all due to the physics of the universe ----
One needs to consider the two flavors of energy : Dissipative and Stored
Dissipative is the one that gets hot.
You can store energy as potential ( a brick on top of the cupboard)
or as a Kinetic , (a brick swung horizontally on a piece of string)
you can swap back and forth ( a brick swung in a vertical loop)
In all cases when the brick hits you , energy is dissipated according to its velocity, and the amount of reaction force.
Lets drop a rubber ball from 5ft , it bounces back to 4ft,
Lets drop a gob of putty from 5ft , it doesnt bounce.
Lets drop a massive steel ball 5ft , it bounces back to 4ft,
Ok whats the same, and whats different?
The rubber ball with initial energy 5units, split this off into one unit of dissipation, and 4of stored energy.
The ball is obviously a higher quality bouncer than putty, lets define the quality factor of the ball
as the
ratio of stored energy to dissipated energy, i.e 4ft/1ft = 4 so
Q = 4
What about the Steel ball ? obviously Q = 4 for it also,
The putty, Q = 1
But the ball is "harder" right, so lets define an impedance Z as the ratio of force/velocity
Both balls bounce at the same frequency so this frequency is independant of Q or Z
All of the above is true throughout the physical universe, be it planets, or balls, or compressed air, or plastic rulers, springs, tyres, magnets, motors, electrical circuits,
I may have skipped 2pi here and there , refer here
http://en.wikipedia.org/wiki/Q_factor ---- Reactance-Frequency Chart -----
Get one of these, it's is the only piece of paper (except for birth certificate) that I've kept for the last 50yrs.
Here is a typical one
http://www.rfcafe.com/references/electrical/frequency-reactance-nomograph.htm ------ R L C -----
There are two very important concepts Q=quality factor , and Z = impedance.
As Q is the ratio of reactive/dissipative it is also the ratio of the resistive impedance to the reactive impedance.
Consider a 1000uF capacitor in series with a 1ohm resistor , being used to filter a power supply that has ripple at 160Hz
So at 160Hz, the impedance of the resistor is 1 ohm , the reactance of the capacitor is -j1ohm , the Q = 1/1 = 1 at 160Hz
Lets make it more interesting and throw a 1mH filter inductor in there , surprise it has an impedance of j1ohm at 160Hz,
so there we have a resonant circuit with Q=1 , at 160Hz, the total series resistance is 1 +J1 -J1 = 1ohm .
Oddly enough it doesn't matter how you wire up these three components, you always get the same Q.
Now this Q is inversely proportional to your k , e.g. Q = 1/(2k)
Q is also the ratio of bandwidth to resonant frequency.
Q is approximately the ratio of the energy lost from successive cycles.
So its a two step process
figure out the impedance of the parts at the frequency of interest
Then
work out the Q from the ratio. Once you have these, everything else fits together.
Lets build your radio transmitter now, let's make it operate at 1.6MHz , so take your chart, look horizontally along at 1.6MHz , there are hundreds of possible choices of L and C combinations (the 45deg lines) , each corresponds to a certain impedance (the X axis). Lets assume we have a certain output transistor which has an effective resistance of 10ohm, That kind of suggests 10nf and 1uH as the resonant parts , but we really want the transmitter tank to be swinging on its own with just a little push from the transistor , typical transmitter tanks run with a Q of 12-20 , lets make it Q=10 , So to make a Q of 10 with a 10ohm transistor we need 100ohms of reactive components, which is 1000pF and 10uH.
So in keeping with Q=10 , we might input 10W from the transistor, and have 100W bouncing around inside the tank, i.e. there will be 1amp of collector current and 10A circulating. The other reason to have some Q at the collector is to suck up the second harmonic , the second harmonic is at twice the frequency, so L and C will be 20ohm and 50hm , so the "gain" at 3.2MHz is only 0.5 , while the "gain" at 1.6MHz is 10,
So now we have a resonant circuit with Z=100ohm but we have a 50ohm antenna to attach to it , we also need an output filter as our second harmonic is still too high. Lets make another tank with 200pF // 50uH = 1.6Mhz = 500ohm, Q=10 , Where do we put the antenna wire? simple , make the 200pf as a series combination of 220pF + 2200pF , the bigger capacitor connects to ground, so what are the impedances? Approximately -j50ohm and -J450ohm , so just attach the antenna across the 2200pF. The antenna now also has 10W of real power, and 100W of reactive power (but the volts and amps are 5x and 1/5 that of the Transistor tank)
Now we need to connect the two tanks , obviously a straight piece of wire will detune both tanks, there are numerous possibilities, here I will top couple the two coils, so a small capacitor between the tops of each coil, to keep our Q of 10 on the antenna tank I'll set Z capacitor = 10 x Z tank = 20pF , this is a pretty sloppy way to do it, but once you tune up each coil, all the power going in at 1.6MHz at the transistor will appear at the antenna, whereas only about 1% of the 3.2MHz will appear there.
So you can pretty much design the whole thing using just the chart and a pencil, Just like Marconi and Tesla.
