Hi everyone,
I've got a desktop lamp that looks roughly like this
The base contains a power switch, a fuse and a cheap 220V > 12V transformer and the arms of this thing are acutally used to carry the current from the transformer to the lamp.
The fuse is rated 250V 6.3A while the bulb is supposed to be a 12V 35W unit, so I was wondering is 6.3A for the fuse wasn't too much and possibly unsafe.
I actually went a bit rough on the lamp and shorted the arms, the fuse blew but it took approx. 3s which seems "long" for a safety feature.
What do you think about it ? Should I use a 6.3A fuse or one with a lower value ?
Thanks in advance for your help.
