Author Topic: Circuit response changes when I put my hand near it.  (Read 2732 times)
Offline captainscarletTopic starter
« on: June 28, 2013, 11:48:29 am »
I don't know if this is a common occurrence, but I'm building an 8x8x8 LED cube at the moment and I'm in the process of debugging some problems.
First off, there's 64 anode column pins and 8 cathode layer pins. Now, some of the LEDs light up even when the cathode pins are not connected to ground. I presume that indicates a short somewhere, maybe the current is sinking to a logic 0 pin on the latch.
I'm also getting a substantial ghosting problem with nearly all the LEDs when I connect everything up.
But I'm seeing that the LEDs flicker when I put my hand near to some of the ICs on my stripboard. I grounded myself, but I'm still seeing some response.
Can anyone give me an explanation for this?
Offline Skimask
Re: Circuit response changes when I put my hand near it.
« Reply #1 on: June 28, 2013, 12:14:31 pm »
"Hand capacitance"
"Skin effect"
"Magic"
Google
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline Paul Price
« Reply #2 on: June 28, 2013, 05:57:32 pm »
The effect is caused by one or more pins on an ic on the circuit board that is an input pin and is not being pulled up or pulled down a connection to anything., it is.just floating and since it is a very high impedance it is able to be reacting to the electrostatic fields of your hand. Check you circuit carefully for floating inputs.
Offline MacAttak
« Reply #3 on: June 28, 2013, 11:31:03 pm »
It might be helpful if you have a schematic to share that shows the design. Might be a bug.
Offline drew_the_mutant
« Reply #4 on: June 29, 2013, 04:04:56 am »
Magic is bad.
http://www.outpost9.com/reference/jargon/jargon_46.html
"It was clear that this switch was someone's idea of a silly joke. Convinced by our reasoning that the switch was inoperative, we flipped it. The computer instantly crashed. "
« Last Edit: June 29, 2013, 04:07:02 am by drew_the_mutant »
Offline KJDS
    • my website holding page
« Reply #5 on: June 29, 2013, 09:29:35 am »
You either have something oscillating or an open gate input.
