Author Topic: Class D Amplifier Design Help  (Read 2147 times)
Offline sonnytigerTopic starter
  • Life is pretty enjoyable, eh?
« on: February 06, 2013, 03:29:47 pm »
I'm looking to build an amplifier to power a 4 Ohm 6 Watt Speaker, possible configured as two in series, I'm looking to use one of these chips or possibly others if they are suggested:
http://www.ti.com/lit/ds/symlink/tpa3004d2.pdf
http://www.ti.com/lit/ds/symlink/tpa3117d2.pdf
using this one i would only have to use one chip to power the four speakers i intend to use in the final product:
http://www.ti.com/lit/ds/symlink/tpa3110d2.pdf
One problem I can't figure out is the effect of using the 3.5mm (the small headphone style jacks) output from the back of my computer, when the chips all expect differential input. Is this a problem? Will it work? I don't know. Any help appreciated, thanks!
Offline c4757p
  • adieu
Re: Class D Amplifier Design Help
« Reply #1 on: February 06, 2013, 03:33:41 pm »
Read the whole datasheet, it tells you how to use a single-ended input.
« Reply #2 on: February 06, 2013, 03:41:57 pm »
The first one does? or all of them? I skimmed through but i must have missed it.
ah okay yes I have found it thank you.
« Last Edit: February 06, 2013, 03:43:45 pm by sonnytiger »
Offline c4757p
  • adieu
« Reply #3 on: February 06, 2013, 03:51:00 pm »
I don't mean to be rude (I know nobody really appreciates a cold "RTFM!"), but these are somewhat complicated chips. It's going to bite you in the ass if you don't read the datasheet all the way through.
(By the way, I didn't read them all the way through either, I just hit Ctrl-F and typed "single".  :))
« Reply #4 on: February 07, 2013, 12:14:14 am »
No problem, thanks for the help!
