I'm reposting - or maybe trying to remember to hit POST this time. IF for some reason my previous post on this was removed please let me know why.
In my TTL CPU project I need to create a derived pulse about 80ns shifted from the pulse I already have. I have a few chips like memory that can take that long to get output ready, so I need to split the clock between the "slower" chips. Unfortunately my google foo is not up to snuff here - I get a lot of patents on much more complex circuits creating 6, 8 or more separate frequency intervals. I like the idea of using flip-flops but I cannot find something that tells me how to calculate the time a flipflop takes. I've also thought about the non-overlapping 2-phase frequency that seems a bit extreme though when all I want is a slight pause between the signals, and I would still like the "write" to be high/active while reading is going on.
I'm on a learning quest so I'm really looking for something to explain how things work, so I can understand why circuits would be designed this way, and figure out how to adjust it. I did btw. try a few inverters and that only gave me about 20ns or so. I don't have a ripple counter IC available, and I did find some materials that advised AGAINST using ripple-counters for this.
So I'm looking for sources can help me understand how to do this. Thanks.
