@megajocke: In the end I found some resistors that are pretty decent matches. Most problematic were those for the E3616A: instead of 0.6R I ended up with 0.604 (5W) and 0.619 (10W). I guess that shouldn't cause any problems
@poorchava: Thanks for the offer
I actually moved to Hungary a while ago, and I think I should be able to get some transformers custom made here for prices comparable to those in Poland.
For initial development though I'm planning to use a transformer I found on a local auction site here. The HP service manuals unfortunately don't contain any info about the transformer. They use three windings for the main circuit and use some SCRs to enable one or both of the additional taps, and have two more secondaries for the various bias and reference voltages.
I think the transformer I found is a pretty decent match for an E3615A (20V/3A) or E3616A (35V/1.7A). It has four 16VAC 4A secondaries plus a bunch of auxiliary ones. My only worry is that perhaps the winding for the +15/-12V circuit is a bit weak. It's only rated for 300mA. I must confess that I have absolutely no clue how much current an opamp would need. What do you guys think, is that 300mA enough to power both the +15V and -12V rails?
@Jonas: I think I've seen all of Gerry's PSU videos, the repair videos as well as those about his own PSU project, some really interesting stuff there!
I'm afraid I'm not quite ready yet to build my own PSU from the ground up, like Gerry is doing. That's why I figured I'd start with copying an existing design and make some gradual changes once (if...) I get it all to work.
Some of the changes I've been thinking about are:
- digital programmability using an ADC and DAC (now there's a novel idea )
- updating some components to more modern (and more obtainable) versions. In particular the OVP circuit, which currently uses an overvoltage sensing IC that is rapidly turning into unobtanium...
- perhaps turning the whole thing into an E3631A-ish configuration with three independent output, basically combining an 8V/6A model with two 35V/1.7A models.
Thanks for all the help so far! I've ordered a whole bunch of components from Mouser, can't wait for them to arrive and actually start building something!
