Hello friends. I am being told that the water tank has a capacity of 100cm level. The desired level is 80cm. How should I calculate the control valve constant (Kv)? Q(s)=KvP(s). Q(s) is the inflow rate, P(s) is the pressure driven into the control valve Kv.
