Hi guys,
I'm trying to design a circuit using only an N-FET and a resistor that performs with the basic inverting amp characteristics, but I want it to work with both a + and - VDD. Any suggestions? I'm sure this spec will require more components than an N-FET and a resistor. I tried to come up with a circuit that introduces a diode in series with GND so that when Vin (gate) is pulled low, Vout is VDD (where VDD<0). Below is a truth table of what I want (the last line is the only one that is a problem):
Vin (VDD>0) Vin (VDD<0) Vout
high 0
low VDD (>0)
high 0
low VDD (<0)
VDD
R \
-----o----------o Vout
Vin ----|
GND
Thanks a lot!
