so what is the minimum for them motors i cant find no data on them
Well, you have measured that the motors take 1A at 12V, no? Or how did you determine that? Or what did you mean by "im running them of a 1A 12v "?
If its coils have 10\$\Omega\$ resistance as you have mentioned, then at 12V you end up drawing 1.2A when the motor is standing still.
It is a Mitsumi motor, likely a custom variant made for some printer or copy machine. The closest part seems to be their M42sp-6k:
http://www.mitsumi.co.jp/latest/Catalog/compo/motor/m42sp6k_e.htmlThere you can see that it is both rated for 21-26V operation and only 550mA peak current, with 8\$\Omega\$ winding resistance. And it also says that the drive method is "constant current". So you need a driver that can do this.
The L293D will not limit the current in any way and you end up either destroying the driver or the motor (or both). With L293D you could probably drive the motors from 5V max - that would give you 5V/8\$\Omega\$=0.625A current, but likely less due to the losses in the L293D itself. However that will cost you in the torque of the motor and it will still be running hot, potentially burning itself out over time.
There is a reason why chips like the Allegro A4983/A4988 stepper drivers (used in the popular Stepstick modules) have an adjustable current limit!
