Hey all,
I've been fooling around with a very simple Colpitts oscillator, and ran into a surprise when I tried to throw an op amp in front of it to buffer its output.
First shot is of the unbuffered Colpitts oscillator circuit.
Second shot is of the pin I've labelled "output", as well as an FFT. I found this pin to be the smoothest sine wave.
Shot three is the buffered circuit. I've used an LM324 mod file.
Shot four is a plot of both the input and the output of the op amp. As expected, they match almost exactly. This is with a 3V supply powering the Colpitts, and 15V +/- rails for the op amp.
Shot five is where the problems begin. The supply to the Colpitts has been turned up to 5V, and we are starting to see some distortion on the output of the op amp.
Shot five is with the Colpitts supply turned up to 9V. What the heck is going on here? At some point I'd expect to see clipping as I get closer to the op amps supply rails, but this output waveform has turned into a triangle! Its as if it somehow no longer has the slew rate to keep up with a 33kHz input?!?
Can you pros hit this newb with a clue bat please? What am I missing here?
(I've also tried this circuit with an LT1001 with similar results, so I don't think I have a bad LM324 model)
