Hi Experts,
I have two 2600mah power banks.
Is it possible to increase output current, if I join output terminal of both circuit together in parallel.
As both these circuit board gives out 5v/1Amp each, would I be able to get 5v/2Amp output.
Similarly, I will also connect USB input terminal together in parallel, so both cells will charge simultaneously.
Does, joining output harm my powerbank circuit or my device?
Please advice.
Thanks
Prashsax
