Author Topic: Communications Engineering - Where to start ?  (Read 1413 times)
Offline alin_imTopic starter
« on: June 12, 2015, 11:55:22 pm »
Hi guys,
I am a final year student at Communications Engineering. In my second year I started to communications (AM, FM, PCM, Noise) and i find it very interesting but also very hard (high frequencies, many parameters that can influence the circuit  :blah: :blah: ).
My questions are: Where to start from ??? What books do you recommend with applicability and practical circuits ??? Any basic circuits that every "mini electronics lab" should have in this field ???  :wtf: :-//
There are so many topics on this and it is overwhelming. Also keep in mind that my best equipment so far are a 40  MHz oscilloscope, 2 x 1MHz signal generators, 2x DMMs and a decade resistance box and some LM317 and LM337 PSUs. Keep in mind all the equipment is vintage, nothing too fancy.
What should I buy / make, where should i start ???  :scared: :scared: :scared:
One man's 'magic' is another man's engineering. 'Supernatural' is a null word. - Robert A. Heinlein
Offline German_EE
Re: Communications Engineering - Where to start ?
« Reply #1 on: June 13, 2015, 07:40:59 am »
Experimental Methods in RF Design - Wes Hayward
The ARRL Handbook - ARRL
The Radio Communications Handbook - RSGB
Single Sideband Circuits & Systems - William Sabin
Solid State Design For The Radio Amateur - Wes Hayward
The last publication is now out of print but it's well worth trying to borrow a copy from someone. You could also try to find your local Ham Radio club where, hopefully, you will get more ideas.
Warren Buffett
Offline dmills
« Reply #2 on: June 13, 2015, 03:09:01 pm »
Solid state design was IIRC the predecessor to EMRFD, so there is probably little to be gained by hunting both down.
Other then that, yea good list.
Regards, Dan.
« Reply #3 on: June 13, 2015, 05:59:36 pm »
thank you for your recommendations !!! any useful circuits that i can build ???
