thinking about it its rational, but it just came to me when i was simulating my preregulator circuit using a comparator as so called "novel" SMPS PWM generator, because i trust a comparator somewhat like a logic circuit only producing HI or LO output. but then due to unbehaviour of my simulation (my supposedly SMPS circuit went into linear mode and the mosfet is going to burn like fire) tracing my circuit, i realized the comparator setup is just as similar as a gain opamp and hence went to a stable mid voltage output in the rail, how can this be? its a blasphemy! now i'm adding logic circuit upfront the comparator so i can further ensure only HI or LO is produced, is this a rational move? i dont know, the Tina simulator doesnt have logic part to simulate with.
and then googling "comparator as an opamp" gives very very few result, 1 in a million maybe, the rest of 999999 are talking about "opamp as comparator" the vice versa. but one thing special about this 1 link, is the text is talking about using an MCU comparator as a gain voltage opamp, this is just
but reading it its typical using RC filter. but then, unlike MCU's comparator (which can produce only HIGH or LOW, through digital flip flop), analog comparator like 393 is subjected to the opamp behaviour without even the need of RC filter. maybe this MCU opamp setup can be applicable to my next project, just saying.
http://electronicdesign.com/analog/get-extra-op-amps-using-spare-comparators
