Hi every !
I designed this circuit below , the purpose is to "convert" a signal from +/- 10Vac , 400Hz , into a 0 - 5 Vdc .
I used an AD790 powered by a +/- 15 Vdc supply , the particularity of this comparator is the output which can be TTL ( see the datasheet) so Vlogic is 5 VDC .
I add a +/- 100 mV hysteresys with external resistors , but it still oscillate a bit .
So wonder if i add a feedback capacitor , will it be better ?
How do you determine the value of the feed back capacitor ?
Thx
Sorry for my english
