Author Topic: Compiling Firmware  (Read 1529 times)
Offline davidleverett30Topic starter
Compiling Firmware
« on: May 08, 2017, 10:12:48 am »
I have bought an inemo-M1 IMU and would like to change part of the firmware (I want to use the SPI external interface on the board).
I have the source code (C/C++) and can see the (SPI) driver to use, however, the documentation doesn't explain how I update the code.
I can only assume that I need to take the existing code, drop the driver into the correct folder and then compile it.
The firmware is in .hex format. C/C++ ---> .hex
To be honest, this is the first time I've done anything like this and it is pretty confusing. Where should I start?
Offline Matir
    • SystemOverlord
Re: Compiling Firmware
« Reply #1 on: May 08, 2017, 03:05:52 pm »
Is the code somewhere public?  Does it have a Makefile or any build scripts?
« Reply #2 on: May 09, 2017, 03:48:48 am »
I've made some steps forward.
I looked into the source code until I found something called MDK.. googlig... this lead to an ARM-MDK software that can compile the code into a hex.
There is a file with the extension .uvproj with a list of everything my hex file should include.
I have enabled the SPI stuff and will then compile the code. I'll update the board tonight.
This dude was a big help:
