I've been looking for something good for storage. Originally I put different resistor values in individual drawers in a Stack-On storage container. That was 12 years ago, and when I started doing electronics more full-time a few months ago, I purchased two more matching containers. I was disappointed they didn't really match. The drawers in the modern ones are generally flimsier. I wrote a complaint to Stack-On, but I am pretty sure they plan to continue building them with the flimsy drawers instead of going back to the better ones. By searching hard, I was able to find three or four companies still making them with the clearer, stronger drawers, but they are very expensive.
So, my girlfriend and I went out shopping for something different. We found some flat Rubbermaid containers at WalMart. They are still made of the cheaper material (polypropylene instead of polystyrene), but they are less flimsy than those thin-walled drawers. We were concerned about the polypropylene material easily building up a static charge and possibly damaging the components, so we sprayed the interior of some of the containers with MG Chemicals 841 Super Shield Nickel Conductive Coating. That didn't work so well, because the nickel spray doesn't stick to the container very well. It tends to come off easily, so I haven't really used the ones I sprayed. I used one for components for specific projects I am currently working on, and kept the components in bags inside the storage container so they don't get nickel metal on them from the spray-on coating.
The one I did not spray with conductive coating I use for connectors, and that seems to work well. I would like to buy more of these containers, but I took off the stickers so I don't know the model numbers, and I can't find them on the WalMart or Rubbermaid web sites.
We have chosen to stock up on mainly 0805 size components, and I bought a whole kit of over 17,000 resistors (100 of each value) from vakits.com (in Florida, USA), and they came in plastic bags, which is not ideal, but for now they are still in the bags they came in. For capacitors, we have only bought a few values so far, in quantities of 50 to 100, so I kept them in the bags from Mouser, and added a note card to each bag, taped the SMD components to it, and labeled the note card with "Capacitors 0805," value, voltage rating and tolerance. I was hoping I could eventually find a drawer that will fit all these, like a library card catalog.
I will look through the forum for other suggestions. The one thing I like about my storage right now is the flat Rubbermaid container with the connectors in it. It has dividers for configurable size compartments, up to 24 compartments per container and the containers are stackable. But I don't like that it seems not to be good for static-sensitive components.
EDIT: I went back to WalMart and found those containers again. The item number on the tag is 151200 for the large one, and 151203 for the small one. I bought more of the large ones today, because I have found them very useful for storing connectors and IC sockets.
http://www.walmart.com/ip/Rubbermaid-Large-Storage-Box-Clear/17474207http://www.walmart.com/ip/Rubbermaid-Medium-Storage-Box/17208933
