Hello Everybody.
I would like to know why copmuter power supplies go so heavy on the 12v, 5v and Ground wires.
For instance. the 24 pin mother board connector.
8 of those wires are just for ground.
5 of them are just for 5 volts.
4 of them are for 3.3 volts
2 of them are for 12 volts
Why are there no power supplies designed where its just 1 thick black wire all the way to the motherboard from the power supply and then at the 24 pin connector it branches out to the different pins.
And the same thing goes for the 12,5 and 3.3 volt rails.
The connector you see there is the "improved" version, the tiny 4 pin extension was added later in such a way as to preserve backwards compatibility.
When the first ATX power supplies were made, the processors and the memory was powered from 5v and 12v was used only for computer fans and motors in mechanical drives and optical drives. That's why you see only one 12v wire in the 20pin block.
The NC pin was in previous versions used for -5v , which was present in the ISA slots and often used in sound cards for the audio amplifier on the boards (for example power opamps with -5v .. +12v ). Since a few versions of the ATX standard, the -5v is deprecated and can be missing. So one of the ground wires was for this -5v wire.
-12v is also on its way out and on most modern motherboards it wouldn't be a big deal if it's gone. It's pretty much used only for serial ports these days, and those are pretty much only as headers on most motherboards and people don't use them.
5v was also used a lot by PCI slots
3.3v I guess was used mostly by onboard stuff like onboard audio chips, extra sata controllers , firewire, onboard network card... and some PCI slots are 3.3v and 5v (universal)
Some versions of AGP had 3.3v but I think by that time most motherboards used dc-dc converters to produce the agp voltages from 12v .. unless i'm very wrong, by the time of agp 8x they were already down to 1.25v or something like that.
The ATX connector itself has a rating of 9A per circuit and the contacts have a guaranteed resistance of 10mOhm .. however, the ATX standards drop the maximum current per circuit to something like 7-8A per circuit (ex 8A per circuit in the case of 4 pin cpu power connector and 7A per circuit for the EPS 8 pin cpu power connector)
So assuming 7A per circuit, the 20 pin block would have only 4 circuits x 7A =
28A on 5v and 3 circuits x 7A = 21A on 3.3v ... which when you think about was not much when mb+cpu+memory was powered from that connector..
Also keep in mind that while we see AWG16 or AWG18 wires used these days which can carry up to 16-20 amps easily per circuit with low resistance per meter (i think it's 21mOhm per meter for AWG18) , back then it wasn't uncommon to use AWG20 wires which have about 33 mOhm resistance per meter and are rated for around 10A per circuit - so it made sense to use multiple circuits to reduce the current per circuit and have less voltage drop on the individual wires.
The extra 4 pins in the 24 connector is a latter addition, which helps mostly with 12v .. as often the pci express slots are powered from those two 12v wires along with fan headers.
Note that recently some power supplies use one of each 5v and 3.3v pins as Vsense wires instead of carrying power to the motherboard (or in addition to carrying power, they hook an extra vsense wire to one of those pins for extra voltage stability)
