Just thoroughly read
this article on impedance, and understand that a voltage divider works with complex impedances as well as pure resistances. Then once you understand the basic function of an op amp*, you can figure all these out with just a bit of algebra.
*The most basic, useful explanation of an 'ideal' op amp that I can think of (one of them, at least) is that the inputs take no current, and it moves its output towards the sign of whichever input is higher, in an attempt to make both inputs equal. If it cannot make them equal, it's said to be saturated. Once you've ascertained that it is able to make them equal and has not saturated, just calculate the output based on the assumption that both inputs are equal.
