Author Topic: Confused about power supply design  (Read 4177 times)
Offline elliot42Topic starter
« on: May 04, 2012, 05:09:20 am »
I have a salvaged 12V transformer and enough spare parts to make a variable power supply (maybe with a fixed 5V line as well).
I'm looking at the schematic for the Silicone Chip Multi-Power Bench Supply and I'm confused about how they get 27V from a 9V AC supply.
I can see how the 13V is the Vp of the 9V RMS after it's been (half wave?) rectified. But I can't figure out how the other lines can get +/- 27V.
Can anyone give me any hints?
Re: Confused about power supply design
« Reply #1 on: May 04, 2012, 05:14:35 am »
Oh, I think I'm wrong there. If the input is 9V RMS then the Vpp should be ~25V.
Then does the 13V/27V have something to do with being half- and full-wave rectified?
Offline IanB
« Reply #2 on: May 04, 2012, 05:15:33 am »
D3 and D4 with the nearby capacitors make a voltage doubler.
Offline amspire
« Reply #3 on: May 04, 2012, 05:15:46 am »
9V AC is 9 x 2 x 21/2 = 25.2v peak to peak.  D3, D4 and the caps forms a voltage doubler supply arrangement that will give 25.2 minus 2 diode drops or about 24V. I assume they measured 27 as the cheap transformers in the plug packs are probably more like 10-11V AC at no load, so 27V is very possible.
Richard.
« Last Edit: May 04, 2012, 05:38:05 am by amspire »
« Reply #4 on: May 04, 2012, 05:29:09 am »
Thanks, that was quick!
Now that I know the type of circuit it looks just like the Greinacher voltage quadrupler described on Wikipedia:
Offline MikeK
« Reply #5 on: May 04, 2012, 11:53:13 am »
How do the diodes work to double the voltage?
Offline ModemHead
  • No user-serviceable parts inside.
    • Mr. ModemHead
« Reply #6 on: May 04, 2012, 12:16:47 pm »
Look at D3 in the original schematic.  Looks like it's the wrong way around, right? But on the negative half-cyle, it conducts and allows the capacitor to charge. Then on the positive half-cycle, you have the transformer winding and the charged cap in series, doubling the voltage.
Offline Psi
« Reply #7 on: May 04, 2012, 12:33:01 pm »
Simply put.. the diodes allow AC to charge the capacitors in parallel while you discharge them in series.
This means you can double/triple/quadruple/... the voltage by adding extra diode+capacitor sections.
I've seen animations showing how the current flows. should be easy to find if you have a google.
« Last Edit: May 04, 2012, 12:34:46 pm by Psi »
Offline MikeK
« Reply #8 on: May 04, 2012, 01:37:34 pm »
Thanks, guys.  Now I understand.
Offline Online Simulations
« Reply #9 on: January 31, 2013, 12:34:09 pm »
In essence, you have diode voltage doubler as the input part of your scheme (diodes D3 and D4 in your scheme)
Actually, this scheme with full explanation is given in:
http://www.cirvirlab.com/index.php/tutorials/92-diode-voltage-doubler-circuit.html
and there also possibility to see waveforms by simulating the circuit in:
http://www.cirvirlab.com/simulation/diode_voltage_doubler_circuit_online.php
