I get the idea behind pull up resistors. You want the pull up resistance to be much smaller than the input impedance of the pin, so that with voltage division, you'd still have an input voltage close to 5V at the pin input.
Here's how I understand it, X marks the voltage at the pin input
5V ----pull up resistance ----- X ------- input impedance ----
I'm a little unclear on pull down resistance, specifically how large the value should be. One source says pull down resistance should be much larger than input impedance, like this one:
http://www.resistorguide.com/pull-up-resistor_pull-down-resistor/but the reason they gave is not intuitive.
Another source talked about current sinking/sourcing at the pin, which confused me. Other sources like Sparkfun only glossed over pull down.
Please advise on the appropriate value for pull down resistor, and briefly explain why.
Thanks
