Many thanks w2aew for your informative videos, you have made resonance of a parallel LC tank circuit much clearer to me.
So as I understand it, when there is an rf signal with a frequency that matches the resonant frequency of the parallel LC tank circuit, the circuit is open to ac signals so maximum signal is passed, rather than be shorted to earth.
Using a variable capacitor changes the resonant frequency, so allowing different input frequencies to be selected.
Is this correct?
Does a regenerative receiver feedback the output of/to the parallel LC tank circuit so making it oscillate?
What coil have you attached to your frequency counter to check the frequency of the DIP meter? Do you use an amplifier for picking up the signal?
Cheers
