Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Connect heatsink to mains earth or isolated ground (transformer)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Connect heatsink to mains earth or isolated ground (transformer) (Read 2424 times)
Spikee
Frequent Contributor
Country:
on:
November 17, 2012, 05:12:30 pm »
I'm currently building a constant current load an i use a big fan assisted tunnel heatsink.
My power resistor (100w TO247) and my mosfet (TO220) are both isolated from the heatsink. ( mica plates and plastic washers).
I use an transformer to power my project so it is isolated. My case is aluminum and is grounded to mains earth.
Now i'm not sure if i need to connect the heatsink to mains earth or the ground plane on my PCB.
Any advice ?
Thanks
Spikee
Logged
Freelance electronics design service, Small batch assembly, Firmware / WEB / APP development. In Shenzhen China
SeanB
Super Contributor
Country:
Re: Connect heatsink to mains earth or isolated ground (transformer)
Reply #1 on:
November 17, 2012, 05:16:24 pm »
If the heatsink is touchable from the outside then ground it to the case. Grounding it to the load side will increase capacitance to ground, so ground it to the case anyway, then the only capacitance is the power device tabs.
Logged
Spikee
Country:
Reply #2 on:
November 17, 2012, 05:22:22 pm »
the heatsink is not touchable from the outside. Thanks for the information!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
