If I have a battery, what is its negative terminal's potential wrt earth ground? Something arbitrary, or are batteries somehow made such that the negative terminal is close to earth ground potential?
If I have 2 batteries in parallel, of the same type (say 9V alkaline), is the construction such that the negative terminals are approximately at the same potential? Thus allowing them to be connected in parallel?
If I have 2 batteries in parallel, of same voltage but different types (say 1.5V Li and 1.5V alkaline) and connect them in parallel, have I created a circuit where current flows from one into the other due to different negative (and therefore positive) potentials?
I guess I want to understand all that before getting to my real question. I think the answers are
- similar batteries have chemistry that places the negative potential at similar values, but they may or may not be at some definite potential wrt earth ground -- we don't know and don't care for small batteries (maybe we care for car sized batteries)
- 2 similar batteries have the same negative potential
- 2 dissimilar batteries do not necesarily have the same negative potential
My real question is, if I have 2 independent, floating power sources (batteries or other) that are powering different devices/signals in the same circuit, and I connect the grounds only (not the +V which would create a parallel voltage situation), do I have a problem?
Say I have a signal generator with its own floating power supply, and an op amp with its own, separate floating power supply. The grounds are connected. The signal from the generator goes into a 20dB gain inverting CMOS op amp input. Does this even work? Doesn't the op amp need to sense the voltage relative to its ground connection, which will be meaningless for the signal since its reference is a completely different ground? Or is it the case that the op amp can still sense the signal potential (aka voltage) relative to the signal's ground, since the grounds are connected?
Or maybe more simply, in a common emitter NPN configuration, where VCC comes from some power supply and the base input is generated by a different power supply. Yes there is a "common ground" at the emitter but it's actually 2 grounds tied together. I think this does work because AIUI the NPN transistor is a current sensing device and current will flow through the device from base to emitter even if the Vbe current flow isn't in the same circuit as the Vce current flow.
This must work because we can attach a portable music player to a mains-powered amp, proving that it does work although perhaps not as I have intuited above.
I am not sure if this works the same for FET transistors since they are voltage sensing (?) not current sensing, and what is the relative point to which the voltage is sensed, given that there are 2 (connected) grounds.
