Have you considered using the leads of the components your are fitting to bridge over the pads? Its a method I use a lot and it makes for a very neat finish when working from point to point. Karl
Yes, this is what I have been doing so far (as in the attached example), but when a few connections remains, it would be nice to make solder bridges, and
this was the purpose of my post (solder bridges without supporting wires).
A big problem when you use the components leads to make the bridges is when you have to change a component. This end up
with some kind of war surgery that you usually want to avoid.
From the above posts, I retain :
- Use single side board (RobertHolcombe)
- Use boards with square pads (klunkerbus)
and the less intuitive but which I will try on my two sided boards :
The secret to bridging a gap with solder is to remove the iron from the joint before you remove the solder. If you just pile on solder it almost never works.
Thanks for these advices. I am looking forward other good recipes for making solder bridges WITHOUT the support of leads.
