I've gone ahead and built the constant current load featured in EEVBlog 102 - I think it's a right of passage. I've used the same parts as Dave - the LM324 OpAmp, and the MTP3055 FET, but I seem to have issues, described herein. I've read through the other posts here about this project, and I didn't find any mention of a similar issue.
The device is currently set up on my breadboard, powering the LM324 with 0 - 12 volts, and with a 7805 (and associated caps) bringing that down to 5 volts for the pot to control the thing. It "works a treat" as Dave would say - the current drain is easily settable and I have no problems drawing more current that I really care to with the thing (I didn't go over 1.5A for heat reasons). The problem is that above 150mA current, it does not stay "constant" if I change in voltage on power supply being tested. It tracks fine below that level, but higher than that point, and it increases/decreases with the voltage. The tested power supply is completely separate from the supply that powers the device, apart from common ground.
I'm asking for advice on what I should be looking at to make this problem go away (if that is possible). I've also followed Martin Lorton's series on the same device, and he doesn't seem to have a problem with the contant current piece. In fact when i fist saw him change the voltage without the current changing I said "Whoa, mine doesn't do that, what have I done wrong?"
My profile says it all - I'm a complete novice when it comes to this stuff with no formal education, so I'm at a bit of a loss as to what I should be looking into.
Many thanks for your advice!
