Author Topic: constant current source  (Read 3198 times)
Offline senz_90Topic starter
  • Country: id
« on: October 26, 2013, 09:49:56 am »
hello, good day everyone. this is my first post.  :D
is there possible we make a circuit that has a constant current source combine with constant voltage based on LM 317 IC?
i think those circuit is very common and simple, so i dont attach both schema. i dont mind if you ask me to attach the schema what i refer to.
« Last Edit: October 26, 2013, 09:51:40 am by senz_90 »
Offline Maturola
Re: constant current source
« Reply #1 on: October 26, 2013, 03:39:52 pm »
Yes It is possible, what type of input and outputs are you looking for?
Here is an example for 5A output.
Sometime when I am alone I Google myself!!!
  • Country: id
« Reply #2 on: October 27, 2013, 12:16:26 pm »
the input is 220v AC step down by transformer to 12v 12v CT. so after bridge diode and filter caps i get around 25-26v? i want the output 1.2v-24v and adjustable current up to 3A. i have TL082 op amp these maybe i can using it.
i dont have a good circuit analysis knowledge. im still learn it but i am need an adjustable psu to powering my experiment project because im learn by doing person type. it is easier to learn by practice a simple circuit. i have made adjustable psu 1.2-24v but it has low Amp that i needed, so i want to rebuild it. i know that LM317 has max 1.5A to flowing. i can purchase LM338 that up to 5A.
this is looks like a dumb question. but i wanna know is that possible we get a higher amp from lower amp transformer amplified by transistor? ex 500mA transformer to make an output 1A?
a little feedback please to help me (noob).
« Last Edit: October 27, 2013, 06:20:53 pm by senz_90 »
