Hi Cobalt232,
Welcome to the forum.
The reason that I use the method that you describe is to test the speed at which the buzzer sounds. When testing multiple points to a common point for continuity, I rely on hearing the buzzer to confirm continuity, without looking at the meter, but focussing my eyes on the point I am testing. Using this method, you don't want to have to wait for the buzzer to sound. If you have to wait too long for the buzzer, quite simply, it takes longer to ring out the points in question, not to mention disrupting your rhythm.
Other folks may have different ideas, but that is why I do it this way.
