Other than that you need to build a variable frequency drive for the motor.
Yea, that's probably beyond my current skill level. At least I'm not keen on experimenting too much with high voltage, even though I do have a couple ideas how it could be done. Ideas like that are much better suited for 5v
I multi-pass my PCBs thru my laminator no problems. I also tape down the print to the PCB (leave the PCB oversize and cut it down later) with Kapton tape to stop it moving.
I've done the same with pretty great results. I actually thought all the toner was transferred, but after a very close inspection, I could see some pixel sized specks that didn't get transferred. Nothing that would matter I think, but I haven't etched it yet, so I don't know. I'd just prefer only having to put it through once and have the results I want. Especially if it were as easy as just putting a $3 ebay item in the thing. Turns out it wasn't.
