I have few computer PSUs of various configurations laying around that are generic lower quality crap that I'd never use in an expensive new system. So (as it's obligatory) I decided to convert them into a bench power supplies, or at least make a project box they can plug into that would expose the different voltage rails as female banana plugs. I would maybe add some extra smoothing and possibly some extra precision voltage regulation and a few LEDs etc etc. You get the idea. The process looked simple, basically it's just a small checklist of things to do that should work with even the most obtuse PSUs. Boy was I wrong...
DELL NPS-300GB B REV:04
Connector:Non-Standard 24-Pin
I knew being dell that it would have non standard pin outs, so the internet once again came to the rescue.
Simply connecting PS_ON (Grey) to Ground (Black) turned the PSU on, no loads or anything else was needed. 5v rail read as 5.1v, 12v rail as 11.8v. (I'm assuming regulation is better under normal load, never had time to test this). Everything was good and confidence was high
FSP Group Inc (Generic crap) FSP350-60MDN Rev A
FSP Group Inc (Generic crap) FSP215-60PNA(PF)
Connector:Standard 20-Pin ATX
This is where I hit problems with both of them:
1. I shorted PS-ON (Green) with Ground (Black).. Nothing, but I know I needed a load
2. I added a 10ohm 5w WW resistor between +5 (Red) and Ground (Black).. Nothing.. Now I'm puzzled. This should have worked as it does with 90% of the videos and tutorials on the internet.
3. I did further research. It seems on rare occasions there's a "soft" power on, so I added a 25K resistor between +5 VSB (Purple) and Ground (Black)... Nothing... Head scratching began.
4. Tried a larger 112K resistor on +5v VSB (Purple), nothing
5. I added an old hard drive to another +5v rail for an additional load.. nothing.
6. I added a 10ohm load to the 12v rail as on even rarer occasions a load is needed on the +12v rail, nothing.
7. Checked that I hadn't somehow killed the PSUs, but both powered on when plugged into a computer
8. Went back to basics, maybe stupidity had kicked in.. Checked and rechecked.. nothing.
9. Stumped and mildly pissed off that something so simple got the better of me, So I went to the pub
Notes:
1. PSUs power on when connected to a computer. The PSU's fan rotates and connected HDD spins.
2. The +5v VSB registers as ~5v with a MM
3. PG (Gray) is not connected as it's just a power on indicator for an LED or other logic.
4. I tried momentary as well as constant connections on the PS-ON (Green) and also the +5v VSB (Purple lines)
Whatever I'm missing, it's got to be something really simple. I've spent too much time looking all over the internet and nothing has worked.
Help please! and Merry Christmas and a Happy New Year to all!
