Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Could a CFL bulb erase a UV EPROM?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Could a CFL bulb erase a UV EPROM? (Read 1951 times)
ali6x944
Frequent Contributor
Country:
on:
April 06, 2016, 05:21:13 pm »
Logged
Gyro
Super Contributor
Country:
Re: Could a CFL bulb erase a UV EPROM?
Reply #1 on:
April 06, 2016, 05:23:59 pm »
Very unlikely, even though they're very bright, the wavelength is wrong. EPROM eraser tubes have quartz envelopes.
Logged
Best Regards, Chris
amyk
Super Contributor
Reply #2 on:
April 07, 2016, 10:26:38 am »
Yes, if left for long enough. I'm not too sure of the physics but I believe that although a specified wavelength will have the most effective erase process, there's a range of wavelengths at which photons hitting the floating gates will liberate their charge.
http://electronics.stackexchange.com/questions/34607/erasing-eproms-with-sunlight
Logged
danadak
Super Contributor
Country:
Reactor Operator SSN-583, Retired EE
Reply #3 on:
April 07, 2016, 10:33:04 am »
Look at spectral range of CCFL vs that required by part.
https://www.google.com/search?q=ccfl+spectrum&espv=2&biw=1517&bih=725&tbm=isch&imgil=_bJSAPhlUWQHsM%253A%253BibjtCEx8_BLV3M%253Bhttp%25253A%25252F%25252Fwww.eizo.com%25252Flibrary%25252Fbasics%25252Feyestrain%25252F&source=iu&pf=m&fir=_bJSAPhlUWQHsM%253A%252CibjtCEx8_BLV3M%252C_&usg=__Vz-zQ7NHRkx3kjDTqI-jbKvO8-c%3D&dpr=0.9&ved=0ahUKEwiMme-JqfzLAhXE7SYKHWljCYIQyjcIJQ&ei=xTYGV8yiEcTbmwHpxqWQCA#imgrc=_bJSAPhlUWQHsM%3A
A UV grow light used for plants would help but still radiant flux level would
make erasure take a long time.
Regards, Dana.
Logged
bktemp
Super Contributor
Country:
Reply #4 on:
April 07, 2016, 10:39:56 am »
A CFL can erase a UV EPROM, but not the typical CFL used for lighting applications.
There are special CFLs without the phosphor coating and being made using quartz glass. Standard glass blocks the UV-C wavelengths needed for erasing a UV EPROM.
Logged
ali6x944
Country:
Reply #5 on:
April 08, 2016, 08:44:36 am »
thanks very much!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
