I know it's a big ask, but would someone be kind enough to briefly explain the 4 stages of this LM324 quad op amp circuit please?
Basically it's an aftermarket automotive device. The input is from a pressure transducer that runs off a 5 volt reference voltage from the vehicle's engine ECU. The transducer reads intake manifold pressure, more pressure seen, more volts out to the ecu input measuring manifold pressure. This voltage would normally go direct to an ECU input, but this device intercepts it. The ecu uses it to determine fuel required and ignition timing required. It also checks the voltage from the transducer, (and hence manifold pressure, it's for a turbo charged engine) does not rise above a preset level set in the ECU programming. If it does, it kills the fuel to the engine by shutting down the injectors.
This schematic is of a commercial device used to clamp the voltage from the pressure transducer at a fixed level, allowing more turbo boost to be run without the ECU seeing an over boost condition. In such conditions it cuts fuel to the engine. What I therefore expect this device to be doing is allowing voltage at the input to pass through unchanged until a preset level, perhaps set by the variable pot. At which point the voltage is clamped and although input voltage rises, the output then remains fixed. So although boost pressure in the manifold is rising the ecu thinks it has stopped rising and is still at a safe level, so no fuel cut off. I am not sure why it needs a quad op amp and what each stage is doing. Nor am I sure about the two diodes on the pressure transducer input wire. Thanks.
