I have put together a LTspice model of the circuit, so we can see the circuit working normally. The circuit is the same as the one in the original post.
There is no fast SCR models included in LTspice, so I made a model based on a switch.
Here are the key waveforms with the circuit operating normally:
The SCR turns off when the diode is conducting. The turn-off time of the SCR Tq must be shorter than the time the diode is conducting.
One of the features of this type of circuit, is they are inherently short circuit proof. I short the output the waveforms become:
The diode and the SCR currents are approximately equal in amplitude.
The main threat to these circuits is an open circuit. If the load voltage is increase, the diode current is reduced:
If you keep raising the output voltage you get below a critical level of diode current and the SCR is unable turn-off.
The fuse is in the correct position. If the SCR fails to turn off, current will ramp up in the inductor and the fuse will blow.
You need a fast inverter grade SCR in this circuit. These may be difficult to find. 20-25 years ago they were manufactured by RCA, GEC (Later Marconi Electronic Devices Limited 'MEDL')
I have attached the LTspice model in a zip file for anybody interested in playing with the circuit.
I have updated the LTspice fileThe file I had attached was an old revision Regards,
Jay_Diddy_B
