Hello all,
I working on some testing for EMI susceptibility. I have an input(sensor) wire that I wish to couple a signal onto. I have a function generator that I want to use to apply different frequencies to the system.
I was going to take the sensor wire and wrap it around a wire with the signal from the function generator. My question is how should I terminate the function generator? Should I add a 50 ohm to the end of the function generator signal? Or would just shorting the ends of the function generator work the best?
A final note, this is not a very quantitative test so I'm not really looking for the perfect solution, just something that I can get working semi-quickly.
Any other suggests also welcome.
Thank you!
