question: I want to use two CR 2032 batteries in series for a project. The load the batteries will see is about 580 Ohms. The current draw from the batteries is about 10mA. On this datasheet (
http://data.energizer.com/PDFs/cr2032.pdf) It gives a voltage reduction curve over time for a 0.19mA draw, my circuit needs to consume 50 times that. So will the batteries voltage decrease approximately 50 times quicker? I know that it is a non-linear relationship between voltage and time for a set load, but is that a good approximation? Also is there anyway better I could get about 5-6 volts to my circuit that I want on a 5X5 cm PCB? I have most of the bottom layer clear, and I want it to be compact.
background: I am designing a miniature version of the "Simon Says" game, for practice in PCB prototyping. The base of the game is the PCB itself, and it will have all four LEDs and buttons mounted onto it. In my eagle file I have the two CR2032 battery holders on the bottom of the pcb. I need at-least 5 volts for the micro I am using.
