If it is only the joints that are cracked, and not the components, some gel flux, and a hot air gun with a narrow nozzle, point it so the air flows between the movement and the plug rather than pointing straight down or at either, the flux will flow then a little later the joints will reflow better than ever.
The key trick is noticing when the joints begin to flow, as that means you can move on to the next component, for that many components, once the hot air gun is up to temp, would imagine no longer than about 2 minutes to reflow all of them,
