I'm still curious as to what people will do with this pulse generator. I've no use for one at all as I rarely deal with pulse trains but it is always interesting to see what other people do with their equipment. There have been lots of times where I've gone "Huh. I never knew you could do that..."
A good question... a few that immediately come to mind:
- General purpose adjustable clock /pulse train source.
- Spot frequency source, it has a crystal derived spot frequency output setting at every decade. Not GPSDO quality obviously but useful for general stuff, particularly calibration / frequency markers for an analogue scope.
- The manual trigger lets you generate a single debounced pulse of variable width. Handy for a reset pulse - checking the bounds of a circuit (eg. CPU reset circuit) in terms of it's tolerance of minimum and maximum pulse widths.
- Likewise, using the rear panel trigger input, a wide range adjustable logic delay.
- With the digital frequency display and 50R output (actually max 10V from a 50R impedance source), you have ample power to drive a bright LED to use as a stroboscope.
- Relay pulser (watch the back EMF).
- Using the rear panel Sync output, you can watch the response of a circuit to a pulse edge (0 -2uS delay to trigger the scope before the edge).
- Mosfet driver for experimenting with / optimizing flyback inverters.
- Variable PWM driver for servos / ESCs / stepper drivers.
- Power dropout duration resistance checking.
All stuff that you
could fabricate with discrete circuits (what can't you?) but handy to have in one box. I certainly wouldn't pay £several hundred for one mind you!
