As long as the crimp is suitably sized for the wire, either stranded or solid, it will work fine
As long as the crimp is suitably sized for the wire, either stranded or solid, it will work fine, Soldering a crimp connector makes it far more brittle, which is even worse when your already dealing with single core wire,
Quote from: Rerouter on September 23, 2015, 12:26:09 pmAs long as the crimp is suitably sized for the wire, either stranded or solid, it will work fine, Soldering a crimp connector makes it far more brittle, which is even worse when your already dealing with single core wire,I don't see how soldering will make it more brittle on a solid core wire. Stranded is another story of course, because you are turning part of the wire into solid core.
