Author Topic: Crimping tool  (Read 3910 times)
Offline CtnTopic starter
Crimping tool
« on: October 26, 2014, 06:41:57 am »
I'm looking for a crimping tool that can crimp a plug like this:
http://i.ebayimg.com/00/s/OTYwWDEyODA=/$T2eC16dHJHoE9n3KgItnBQ%29HzISDIw~~60_57.JPG
From what I read, I *think* I need a non-insulated open barrel crimping tool.
I've looked at so many and I can't seem to find one that handles a 7mm wide open barrel.
Most are F type and they are no good as they have a staggered crimp.
Any suggestions which crimping tool is required?
« Last Edit: October 26, 2014, 08:20:47 am by Ctn »
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Crimping tool
« Reply #1 on: October 26, 2014, 08:03:49 am »
Your link is brocken
Re: Crimping tool
« Reply #2 on: October 26, 2014, 08:21:16 am »
Should be fixed now.
Offline Simon
  • Global Moderator
Re: Crimping tool
« Reply #3 on: October 26, 2014, 08:23:55 am »
yea works, ouch, tough stuff, how many you doing ? might be worth soldering
Re: Crimping tool
« Reply #4 on: October 26, 2014, 08:39:46 am »
36 connections.
Offline Simon
  • Global Moderator
Re: Crimping tool
« Reply #5 on: October 26, 2014, 08:55:35 am »
Well for a one off just solder them ?
Offline G7PSK
  • It is hot until proved not.
Re: Crimping tool
« Reply #7 on: October 26, 2014, 09:57:13 am »
Awesome so hex/round crimping tools are the go.
Will look into these. Thanks guys.
Re: Crimping tool
« Reply #8 on: October 27, 2014, 05:56:37 am »
It's going to be use to terminate 10 awg stranded speaker cable.
It will be pretty much static with no vibration.
Not too sure about current flow. Specs say "40 Amps peak" for the amplifier.
I'm located in Sydney.
I'm not after something very fancy, a cheap crimping tool (not soldering) that will do the job will be fine.
