Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
crystal oscillator question
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: crystal oscillator question (Read 1575 times)
ccesaretto
Newbie
on:
August 16, 2016, 12:34:57 pm »
Hello.
This question is very basic, sorry for that.
For a project I am considering this crystal oscillator:
http://uk.farnell.com/abracon/abm8g-12-000mhz-4y-t3/crystal-12mhz-10pf-3-2-x-2-5mm/dp/2467837
It's different from the oscillators I have previously used because it has four pads instead of just two.
Two of the pads are marked with GND in the datasheet so it looks like they have to be connected to ground.
or not?
Thank you for they help.
Cristiano
Logged
dannyf
Super Contributor
Country:
Re: crystal oscillator question
Reply #1 on:
August 16, 2016, 12:39:45 pm »
You likely had a crystal: tough for an oscillator to have just two pads. A crystal needs a driver to output a clock.
A crystal oscillator is just a crystal plus it's driver.
Logged
ccesaretto
Newbie
Reply #2 on:
August 16, 2016, 01:02:52 pm »
Thank you for the reply but now the confusion in my head is even bigger
At the moment I am using this:
http://uk.farnell.com/multicomp/hc49sm-12-30-50-60-16-atf/crystal-hc-49-4hsmx-12-0mhz/dp/1667016
connected to the two OSC pins of a PIC microcontroller and to the load caps.
I was thinking of replacing it with this:
just because it is smaller. but it has the two GND pins that the first one does not have.
Logged
bobaruni
Regular Contributor
Country:
Reply #3 on:
August 16, 2016, 01:04:37 pm »
Yes it is the same, just has extra pads for mounting onto PCB.
Also remember to change your capacitors to match the crystal, in this case 10pF.
Last Edit: August 16, 2016, 01:06:08 pm by bobaruni
Logged
ccesaretto
dannyf
Super Contributor
Country:
Reply #4 on:
August 16, 2016, 01:20:21 pm »
Both are crystals, not crystal oscillator.
Logged
ccesaretto
Newbie
Reply #5 on:
August 16, 2016, 01:25:57 pm »
Quote from: dannyf on August 16, 2016, 01:20:21 pm
Ok, thanks. Now it is clear
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
