Author Topic: Current capacity of wire  (Read 7450 times)
Offline iceisfunTopic starter
« on: October 23, 2013, 07:59:32 pm »
Hello EEVBlogers
I have a question about a project I'm working on
I am trying to connect some stepper driver + encoder boards with a DB9 interface to a control box, but I don't know how much current I can carry on one of these wires?
The current requirement is 3A @ 5v per phase of the stepper motor
http://www.ebay.com/itm/370423582662
Online Monkeh
Re: Current capacity of wire
« Reply #1 on: October 23, 2013, 08:07:33 pm »
Not 3A by a long shot.
Online IanB
« Reply #2 on: October 23, 2013, 08:12:58 pm »
Two things constrain the amount of current you can carry in a wire:
1. Voltage drop
2. Heat generation
With smaller circuits and lower currents voltage drop is the main thing to be concerned about. Simply take the wire you are considering, find out its size (gauge) and length, determine the resistance and then use Ohm's law to find the voltage drop for the current it will carry. See if this voltage drop is within allowable limits. If not, use a thicker wire.
Offline 8086
    • Circuitology - Electronics Assembly
« Reply #3 on: October 23, 2013, 08:19:19 pm »
Google homework:
Resistivity
Ohm's law
Offline M. András
  • Country: hu
« Reply #4 on: October 23, 2013, 08:20:52 pm »
get the db9 connectors and solder some 0.5mm2 wires or 0.75mm2 to it that rs232 or god knows what cable from ebay will have maximum 0.25mm2 wires in it or even thinner
Online Monkeh
« Reply #5 on: October 23, 2013, 08:23:58 pm »
Because 0.75mm² is totally adequate for 5V 3A at 10 feet.
Offline Rufus
« Reply #6 on: October 23, 2013, 08:44:23 pm »
This http://www.powerstream.com/Wire_Size.htm is a useful reference.
Offline FoXX
« Reply #7 on: October 23, 2013, 09:09:40 pm »
Very nice link Rufus, thanks
Offline M. András
  • Country: hu
« Reply #8 on: October 24, 2013, 03:25:22 pm »
i like to oversize things just to be sure
Online Monkeh
« Reply #9 on: October 24, 2013, 03:29:24 pm »
Oversize? That's undersized. Do the calculations next time.
Offline M. András
  • Country: hu
« Reply #10 on: October 24, 2013, 04:17:57 pm »
well yeah. my mistake its a serious voltage drop
