Hello. I've built a simple PSU based on the two regulator design - with a L78S12 in current limit configuration and a low dropout , 3 amp CS5203 for voltage regulation . It works quite well , but the trimpot I'm using for current limiting heats up a lot.
Is there any way to reduce the current through it ? At anything over 150mA it heats up a lot (as it should actually )
I don't have any simple opamps at hand - the only ones I have are some dual ones which need a two rail supply. And I'm out of quality wirewound pots as well . I do have a lot of triacs , mosfets and transistors
Thank you!
Edit - forgot to add the schematic
