To be sure nothing is wrong with the DMM, such as a calibration problem, short the lead and use the relative mode to zero the input, then try again and report back. Readings should be essentially identical with the polarity reversed for any DC in the 87V, current or voltage.
If the relative mode works, it means the DMM is in cal but it is picking up interference.
