hey all
No idea if this is the correct section to ask.
I want to measure the wattage of a high power LED which is driven by a step up converter
I use a current clamp set to 1:10 and a 1:10 probe, enabled math function of my DSO.
I show measurements as RMS values of each channel.
The boost converter is driven by a 160W PSU, 20VDC. Ground is common for output and input.
I also have a tRMS multimeter here to compare the values I see on the DSO.
What I want to do: adjust the LED's power level using the DSO
Alright. I don't understand this:
If I connect the LED and probe the current with the multimeter, I see around 1.1A on the display.
But if I measure the current with the current clamp I see like 600mA on the DSO.
So I tried to measure the current that flows into the step up converter.
It's the same on DSO and multimeter.
Also, for me, there's no visible difference between the current curve shapes.
Why is there a difference between multimeter and DSO in the LED branch, what's wrong here?
Thanks for enlightment and with best regards,
Nik
