Author Topic: Dac - 16 bit; 0-5V  (Read 1392 times)
Offline Vindhyachal.taknikiTopic starter
Dac - 16 bit; 0-5V
« on: March 07, 2015, 03:24:59 pm »
I am looking for 16 bit dac & 16 channel with 0-5V.
Also application is battery powered, so I need DAC to put in sleep when not required.
I had found this octal dac;low power from TI DAC8568 with SPI interface.
Its 8 channel so I need to use two dacs in parallel. But I didn't find CS pin there.
Is there any other alternative to use 2 dacs in parallel . I have only one SPI in my MCU.
Offline PA0PBZ
Re: Dac - 16 bit; 0-5V
« Reply #1 on: March 07, 2015, 03:31:43 pm »
You can use the /SYNC input as a chip select.
« Reply #2 on: March 08, 2015, 02:09:05 pm »
Thanks
