Hey guys, I wanted to develop a program for a Picaxe PIC to draw stuff to a TV over composite.
The programming part is fine and all, but I'm still having trouble with the electronics, which I'm still trying to actively learn.
I want to produce 3 signals for my B/W output to the TV. 0v for sync, .33v for black and 1v for white. I'm trying to use transistors to send this signal out using two of the pins by pulling to ground when I set a pin to high (Using a Darlington). (Both high: 0v, Other two pins produce .33v and 1v if high)
I'm not sure how to go about this, I'm doing something wrong following guides on the internet, still haven't fully worked out exactly how transistors work in a set-up like this. Although I do have a general idea of how they work. (I just suck at applying it)
So yeah, any help would be awesome. I'm not even sure if I'm taking the correct approach using transistors.
Thanks!
