Hello,
I am using a micro controller to record data from some accelerometers and am currently trying to do a quick test to ensure the data logging is working. I had the accelerometers and micro controller (Teensy 3.6) plugged into a breadboard and recorded some data while I shook the accelerometers around. My concern is that there seems to be some data loss (see attached image) during the logging, where the recorded bit value drops to close to zero and I am not sure what the cause is. Is this common for data logging at high speeds or maybe it has to do with shaking sensors that are just plugged into a breadboard? One other thing is that the ADC reference voltage on the Teensy 3.6 is 1.2V and I was using the 3.3V source on the Teensy 3.6 to power the accelerometers (this will be fixed later, I just wanted to do a quick test of the data logging) so I'm not sure if that could be the cause? Any help would be greatly appreciated! Thanks in advance!
